Sid & Houston Mayeux Project
RV-7A
Elev push rod
Front elevator push rod
Went ahead and knocked out the forward elevator push rod since I was building the rear tube. Drilled the tube and end caps, primed the inside, riveted the end caps, then tucked it away for later.
Holes drilled, ready for end caps
Riveted
RV-7A Home
1549
Cockpit
49
135
279
92
Flight Controls
354
192
Wrap Saga A - Dream
Wrap Saga B -- Victo
Wrap Saga C -- Petit
Wrap Saga D -- Fligh
Wrap Saga E -- Emerg
Wrap Saga F -- Home
