Brief Description: Mounting, drilling adjustment holes for the rudder
With the rudder pedal poles mounted into the plastic bearing blocks (each end), I then took time to emplace them in the front. The only way to adjust the pedals is to drill several sets of paired holes on each side in the forward fuselage longeron through which the bearing blocks' mounting bolts mount. Once I get the seats installed and physically sit in the airplane with my legs out, then I can adjust the pedals and bolt them down in the set of holes that fit best. That means the pedals will fit me perfectly, but they may be a stretch for whoever flies with me.
Drilling the bearing blocks for AN-3 bolts
Seating the rudder pedal assemblies for emplacement drilling
