Brief Description: Installing/connecting the elevator trim servo
Next I installed and connected the elevator electric trim motor to the trim tab, and connected the wires. I used a 6-pin MOLEX plug to connect the 5 wires, and stuffed them into the elevator. Powered 'em up, and ran it: No smoke or fire, and the motor worked (and in the proper direction, too!).
Elevator Trim connected (note the elevator horns disconnected from the push rod)
