Sid & Houston Mayeux Project
Date: 7-19-2013
Number of Hours: 3.00
Manual Reference: Vert Stab
Brief Description: Vertical Stab Top Cap
With the rudder build (including installed end-caps), I now fitted the vertical stabilizer top cap. First I fit the cap into position, match-drilled the holes through the metal flange, and cleco'd the cap in place. I then mounted the rudder to check clearance between the cap and the rudder. I had to sand the back edge of the cap almost 1/2 inch to get a good consistent clearance edge (1/8 inch) and allow the rudder to swing freely.
Next, I must fill the aft end of the cap. The cap is hollow and open-ended on the aft side, and I want that filled (less drag, no water intrusion, bugs, critters, etc). I used balsa wood to make a dam. and filled it with a slurry of epoxy/hardener with micro-fiber for strength. Once that hardens, I'll sand it down flush with the cap's edges and finish the fill.
Cap pitted, cleco'd, trimmed for clearance
The gap that needs filling
First batch of epoxy
