Brief Description: Back-riveting the stiffiners to the rudder skins (
Once the rivets are taped on and the stiffiner is in place, riveting itself is pretty straight forward. Quality control is not tough either once you get the air pressure right (I like 40 pounds for these #3 rivets). The back-rivet spring cage really helps make perfect shop heads on those rivets.
