Brief Description: Bolting, safety wiring the fuel tank attach bracke
Per the plans, I bolted the fuel tank attachment brackets (fuselage and wing sides) with the AN-4 bolt and fender washer. I tightened the bolt only until the washer could not be moved, then safety wired the bolt. I used the bracket itself as the safety wire anchor. The wire job is visible in the next posting.
