Brief Description: Riveting on top front fuselage skin, part 2
Kelli came out and helped me finish the job when Houston needed to go. Kelli does a MARVELOUS job on the rivet gun, keeping the mushroom head planted firmly and flush on the rivets. 100% success!
I, on the other hand, braved the wing spar across my back as I got up underneath and bucked with the tungsten bar and a few handy offset bucking bars.
It takes a certain amount of confidence to rivet this final skin onto the aircraft. You have to be confident that there is ZERO remaining work to be done up under there...
