Brief Description: Spar bulkhead side plate covers, part 1
Trey Herndon, and AF buddy, dropped by while I was fitting the main spar bulkhead side plate covers. I'm installing a small LED map light on the top of each plate cover, wired in such a way that I can pull the wiring out and disconnect/reconnect as required for maintenance.
Trey took a turn at match-drilling the covers to accept LP4-3 pop rivets. Next we through through the wiring and mounting bracket install options for the light.
