Sid & Houston Mayeux Project
Date: 1-21-2013
Number of Hours: 3.00
Manual Reference: Headphone Brackets
Brief Description: Headphone jack brackets part 1
For Headphone jack brackets, I designed two different types. Both have the big and small plugs for the headphones, but they also have 12 volt DC cigeratte lighter-type power outlets. In addition, the copilot has an MP-3 input.
I designed a flat-face bracket with an inboard rib for rigidity. It also has a wide stiffiner plate to mount against the cockpit skin. I drilled and dimpled holes in the aircraft skin for flat-top screws, which screw through the stiffener surface into nut plates on the bracket.
Measuring, cutting, bending
Trimmed, bent, drilled, ready for assembly and paint
Great photo bomb, Snoopy!
