Brief Description: Ethernet pass-through for the avionics sub-panel
The Vertical Power VPX electrical control system receives updates via computer configuration files I download from my laptop via Ethernet cable. Because the VPX is mounted way forward, I wanted an easily accessible ethernet jack that I can simply plug into, so I mounted a dual-female Ethernet jack to the avionics sub-panel. Ops check good!!
Pop-riveting the mounting angles to the ethernet jack housings
