Started initial install on the Dynon autopilot pitch servo. Started by positioning the mounting bracket for riveting against the elevator bellcrank rib. Then immediately removed it...I'll install it later after I'm done using that space for pillows and a plank (lets me lay back in the fuselage for further work).
Also built up the wiring harness for the servo, including installing the D-sub pins. I'll run this harness up the center channels, using adel clamps to keep it clear of the elevator pushrod.
