Brief Description: Running wires for the fuselage/tail lights, elev t
Ran all wiring for the beacons (aft fuselage) and position strobe and elevator trim (tail) through one of my two under-floor wire conduits. I wrapped these wires in split-side mesh conduit to carry back to the tail. The split-side coinduit protects the wire and looks good, while allowing me to split out one tefzel cable (two conductors plus shielding, all 18 gauge) for the beacons.
Image 3 shows the wires mounted to bulkhead 7, running top to bottom. I've got these T'd to run the entire circuit on one power/ground back to the VPX. The 3rd wire connects the two lights' synchronization circuit.
