Brief Description: Adjusting the aft elevator pushrod
After clamping the elevator counterbalance horns flush to the horizontal stabilizer, I connected the pushrod to the elevator horns (which are in the neutral position with the elevators). Then I checked the orientation of the bellcrank to see if I needed to adjust either (both) bearing ends. It looked pretty good, so I cranked down the set screws.
I also checked the elevator's downward (stick forward) travel limit and was surprised to find it limited to only 6 degrees of travel (it should give me 20-25 degrees. Must explore...
