Brief Description: Final assembly of the wing-mounted portion
Cleco'd the rib into place, then turned Houston loose with the pop rivets. The flapper arm alignment looks good (90 degress perpindicular to the hole).
We also ran the wire from the system down the wing's main spar to the root, where we coiled it up and tucked it away until when the wing will mate to the fuselage. That's when we'll mount the fuselage half of this electronic system.
Houston pop-riveting the assembly rib into left wing leading edge
