Welcome to our RV-8 build log
RV-8
Riveted mid side skins
Riveted the LH & RH arm rests and bulkheads together.
Back riveted the arm rest assemblies to the mid side skins. The aft arm rests are not riveted to the side skins at this time.
Cleco'd the mid side skins, outboard seat rib angles, center section side plates and upper longerons to the fuselage.
Riveted the upper longerons to the top flange of the gear towers.
Mid side skin riveted and Cleco'd on
Upper longerons in position
Upper longerons riveted to gear towers
RV-8 Home
3685
Electrical System
Fibreglass
693
Panel
Upholstrey
519
