Welcome to our RV-8 build log
RV-8
Mid /Fwd fuselage skins and structure
Match drilled the inboard seat ribs to the seat ramp supports.
Cut the hole in the RH outboard seat rib and mid side skin for routing the rear seat air vent hose.
Clecoed the mid side skins and structure together and drilled all the #30 holes as per instructions.
Joined the Fwd and Mid fuselage subassemblies and Clecoed the forward side skins, stiffeners and angles in position after deburring the edges.
Match drilled seat ribs to seat ramp supports
Mid side skins and structure Clecoed
Joining the FWD & MID Subassemblies
RV-8 Home
3685
Electrical System
Fibreglass
693
Panel
Upholstrey
519
