Welcome to our RV-8 build log
RV-8
Flap brackets
Made the FL-706A brackets from the supplied angle and bent the FL706B's to match.
Match drilled the brackets to the spar and end rib and then removed the spar to back drill the three inboard rib attach holes in FL-706A
FL-706B
FL-706A
Match drilled
RV-8 Home
3685
Electrical System
Fibreglass
693
Panel
Upholstrey
519
