Welcome to our RV-8 build log
RV-8
Leak tested both tanks
Plugged the fuel line with the fitting provided in Vans leak test kit and installed the fuel cap after wrapping it in a cut off balloon.
Fabricated an elbow from 1/4" soft aluminum tube and flared the one end to fit the vent line fitting and installed a balloon on the other end.
Installed the valve provided in the test kit in the drain flange and pressurized the tank with a hand pump until the balloon inflated.
Sprayed all the joints and rivets with soap water to try and find any leaks.
Well, we couldn't find any so both tanks are LEAK FREE!!
Leak testing RH tank
Fuel cap sealed with balloon
Balloon connected to elbow
RV-8 Home
3685
Electrical System
Fibreglass
693
Panel
Upholstrey
519
