Welcome to our RV-8 build log
RV-8
Tank end rib preperation
Scuffed the flanges of the RH tank ribs to provide a good key for the sealer and dimpled the holes with the same dies used on the skins.
Fabricated the flop tube anti-hang-up bracket for the left tank access cover.
Drilled the holes in the inboard ribs for the vent line fittings and BNC connectors.
Fabricated cover plates for the tooling hole in the outboard ribs.
Flop tube anti-hang-up bracket
Vent line fitting and BNC connector holes
Tooling hole cover plate
RV-8 Home
3685
Electrical System
Fibreglass
693
Panel
Upholstrey
519
