Welcome to our RV-8 build log
RV-8
Fitted the RH tank Z-brackets
Bolted the Z-brackets square to the spar and back drilled the top and bottom holes from below.
The platenuts were then attached to all but the inboard bracket and bolted to the spar, ready for the tank assembly to be installed.
RH Z-brackets installed
RV-8 Home
3685
Electrical System
Fibreglass
693
Panel
Upholstrey
519
