Bobs Ten
RV-10
Elevator
5-10-2012
Cleco Elevator Top Skin to Structure
1336 - 1524
Debur elevator top skins using s/b wheel, file, 400 s/p.
Cleco top skin to elevator structure, starting midspan and alternating to tips. Started with front spar, then ribs and rear spar.
Cleco trailing edge wedge into position.
Mark edges of wedge.
Remove clecos.
Cut to length, and smooth edges with bench sander and s/b wheel.
Cleco trailing edge wedge to top and bottom skins, every other hole.
Match drill closeout tab hole with #30 drill.
Cleco hole, then drill shear clip holes in closeout tab with #30 drill, using clecos in every hole.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
