Bobs Ten
RV-10
Cabin Top
12-4-2014
43-4.1>4,12-3.11
Fit Cabin Top, Install HS Tips
1900 - 2024
Continue to sand and shape cabin top to fit fuselage.
Cleco HS tips in place, final drill using #30 drill, cleco as drilled.
Remove all clecos.
Dimple HS skins for flush rivets.
Epoxy aluminum washers to inside of tip flanges to spread the load of the rivet.
Cleco washers in place.
Remove clecos when epoxy has set.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
