Roberts Web Site
Date:  9-10-2011
Number of Hours:  10.00
Brief Description:  fixing problems
I did my first test on the instrument panel last week and I found a few mistake.......I totally miswired the master relay. I was completly off track ( hook up the battery 12v on the wrong post and bring 12v to the coil instead of a ground) After several hours trying to figure what was wrong, I fixed everything up and now it's all working fine except for my radio (no display). I crank the engine to check the starter circuit and it worked.
I spent a lot of time to calibrate the flap controler, and to be honest, I'm not sure that I'll keep it. I might end up with a simple switch with up and down position.........
