Roberts Web Site
Date:  2-6-2010
Number of Hours:  3.00
Brief Description:  left wing trail edge
I began the day by doing the cutouts on the top skin for the flap and aileron. Position and drilled the small top skin K357-B. Installed the 3 small trail edge skins K359. The critical dimension here is 462 mm from the rear spar to the tip. I began with the two exterior skin and I attach a line from one end to another to position the middle one.
line attach between the 2 exterior skin
middle skin against the line
top skin ready to be primed
Copyright © 2001-2010 Matronics. All Rights Reserved.
