Roberts Web Site
Date:  3-16-2010
Number of Hours:  3.00
Brief Description:  left wing aileron & flap
same process than the right aileron. First I traced a line in the center of each ribs, then measure and trace the lines on the skins. Drilled the skins -----3/32 holes. Positionned the skin on the frame in order to see the lines through the holes. Drilled and clecoed.
