I installed the pitot. Apparently I didn't fit the pitot when it was replaced under warranty last year. So I had to spend quite a bit of time with a file underneath the wing. I lost count of the iterations. I put a flange on the end of the pitot and fastened it to the line running through the wing to the wing root.
I re-installed the pitot control board and wired the pitot and all the status LED lines to the control board.
