I couldn't get access to the location to mount the right spring for the aileron trim, so I had to uninstall the aileron torque tube from the wing. I then drilled and installed the mounting brackets for the aileron trim. Then I re-installed the aileron torque tube back into the wing.
I spent the remainder of the time pulling wire through the wings. I pulled wiring for the HID landing lights, the nav lights, the strobes, the stall warning, the autopilot roll servo. I have all the wire pulled except for the aileron trim and the LED annunciators for the Pitot controller. Theyt will be my first task tomorrow evening.
