Bob Leffler's RV-10
Date:  2-2-2013
Number of Hours:  4.00
Brief Description:  Transponder Antenna, Wing Connector, Ailerons
I wired one end of the RG-400 with a BNC connector for the transponder.
I finished wiring the left wing root connector and installed the connector on the fuselage.
I installed the aileron pushrods on the ailerons. This bolt was next to impossible to install with the ailerons on the wing. They were pretty easy off the wing. I hope that the rest of the aileron bolts go smoothly with assembling this way.
