Finished all the wiring behind the right insert panel and mounted the right insert along with all the EFIS monitor, CO detector, ELT remote, and the all important accessory power jack.
I cut of the ends of the AFS GPS (aka Garmin 18x-5hz) and the Byonics GPS. The AFS GPS is the backup to the Garmin GNT650. The Bonics GPS supports the APRS. I ran both cables through the hole in the glareshield and installed DB-9 connectors on each cable.
