I spent some time cleaning up the edge lines along the window. There is still a couple rough areas and there are plenty of pinholes. I bought some thin line painting tape in hopes that it will work better than the tape I've previously used. I mask the window with the thine tape, then a wider tape, and finally blue tape to keep the plastic covering out of the way. I then applied a very thin layer of micro. I will hand sand tomorrow.
I also applied a little micro to the cabin cover door frame.
