I sanded the micro that was applied the other day. I then removed all the tape so that I could see the state of all the edges. There was still some areas that needed more work. I then applied some new tape and applied a thin coat of body icing around the windows. I'm hopinig that this will be the last coat, then all I need to do is to fill the pinholes on the rest of the door.
