Bob Leffler's RV-10
RV-10
Doors
12-4-2010
Left Door #8
Another day on the left door. Janice provided third hand support. I trimmed about 1/16" off the bottom of the door.
Installed the delrin base for the safety latch. I had to trim it down a bit so that the latch will clear the base.
Drilled holes for the door pin guides.
I still have to remove the fiberglass behind these guides and most likely I will still have a bit of door trimming lerft.
Safety Latch Base
Door Pin Guide
Another Door Phot with No Apparent Progress
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
