Bob Leffler's RV-10
RV-10
Doors
11-26-2010
Left Door #5
Match drilled the holes for the gas strut mount with the Van's part, then installed the planearound.com part in it's place.
Re-hung the left door back on the cabin cover. Ready to finishing fitting the door in the next session.
Punched two 1.5" access holes in the sub panel to allow for wire passge behind the sub panel.
Gas Strut Mount Installed
Left Door Re-Hung
Access Holes Punched in Sub Panel
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
