Spent the good part of the day messing with the door handles. Almost every part needed special twekaing to work right. I probably took things apart and put them back together at least a dozen times.
I cut of the ends of the latch pins, threaded them, then installed the magnetic end pins from ilfyrv10.com.
I then installed the interior and interior door handles and latch mechanism.
