Place two Handle Racks on the C-1014 Handle Spur Gear. Slide the C-1006C Handle Pivot over the handle spur gear and handle racks. The assembly just created will subsequently be referred to as the Latch Mechanism.
Attach the Latch Mechanism to the C-1002-R Door. Operate the latch mechanism so as to cause the Rack Trimmings to extend fore and aft from the latch mechanism and lightly contact the walls of the latch pocket. Mark the walls of the latch pocket around the ends of the rack trimmings. Retract the rack trimmings and remove the latch mechanism from the door. Because of the size of the latch pocket in the door and the length of the handle racks, the latch mechanism must be assembled "in-position" in the latch pocket.
