Bob Leffler's RV-10
Date:  5-7-2011
Number of Hours:  4.00
Manual Reference:  47-7
Brief Description:  Cowl and Cabin Cover
47-7, Step12
Fasten the Cowl Upper Pin Retainer Assembly to the top cowl with the screws. The top cowl hinges had to be slightly modified to accomodat the retainer.
When I attempted to put in the hinge pin, each side got hung up at different locations. The next time I take the cowl off, I'll have to investigate what is causing the problem. Both side hing pins went it just fine.
I spent most of the day filling and sanding on the cabin cover interior. Janice helped a little bit in the morning.
Retainer Assembly installed
More cabin cover sanding.
