Renee assisted me in putting the lower cowl back on the fuselage. There is one adel clamp htting the flange for the ram air. I'll need to cut out a hole for clearance. Renee held up the RAM AIR Scoop and I measured the length of material that was need to join the two pieces. I used the material and adhesive that came in the RAM AIR kit.
The Milspec Products fasteners are going to need readjustment. The thickness of the paint on the two pieces are making them too hard to fasten.
