Bob Leffler's RV-10
Date:  12-17-2011
Number of Hours:  3.00
Brief Description:  Wired G3i Ignition
Wired the G3i ignition on the aft side of the firewall. The firewall forward side will be completed later.
I also fabricate the power cable for the VP-X and the MSD G3i unit which are both connected directly the battery pass through terminal on the firewall. I then installed both, along with the battery cable coming from the rear of the aircraft.
While on our auto store visits yesterday, I purchaed an inline fuse for the MSD. I was uncomfortable connecting it directly to the battery without fuse protection for the wire.
G3i ignition
G3i ignition
Firewall pass through for the ignition
Battery pass through terminal on the aft side of the firewall
