Bob Leffler's RV-10
Date:  6-30-2011
Number of Hours:  0.50
Manual Reference:  FF9-9
Brief Description:  Baffles #7
FF2-9, Steps 1, 2, 3, & 4
Use the hardware to attach the Cylinder 5 Baffle Assembly and Cylinder 6 Baffle Assembly to the engine.
Match-Drill #12 the two holes in the aft flange of the CB-1007D Aft Center Support Bracket into the CB·1006A Left Aft Case Baffle and the CB-1007 A Right Aft Case Baffle.
Install the two bolts that attach the CB-1007D Aft Center Support Bracket to the CB-1006A Left Aft Case Baffle and the CB-1007 A Right Aft Case Baffle.
Use the hardware to attach the Cylinder 14 Baffle Assemblies to the engine.
View from the left
View from the left
View from the right
View from the right
