Bob Leffler's RV-10
RV-10
Ram Air Mod
Brad took apart Rod Bower's Ram Air filter to add another adel clap further forward.
When he put the filter back on the aircraft, we were able to position so that the control arm finally clears the scoop mod.
Clearance with the valve open
Clearance with the valve closed
Added a nutplate to facilitate installing the adel clamp
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
