Final-Drill #19 all the holes common to the S-601-1 Spinner and the S-603 Spinner Front Plate, common to the spinner and Spinner Back Plate Assembly, and common to the spinner and S-1002 Backing Plate.
Remove theS-601-1 Spinner. Drill #40 holes in the Spinner Back Plate Assembly, the S-603 Spinner Front Plate, and the S-1002 Backing Plate for the rivets used to attach the nutplates.
Machine countersink the holes drilled in the previous step for the heads of AN426AD3 rivets.
