Bob Leffler's RV-10
Date:  2-5-2011
Number of Hours:  1.00
Manual Reference:  FF1-4
Brief Description:  Engine #2
FF1-4
Install a KB-OOO Straight fitting into the fuel pump inlet on the right side of the engine driven fuel pump. Install a KB-090-T Tee Fitting to the fuel pump outlet on the left side of the engine driven fuel pump. Install a VA-12B Restrictor Fitting into the female port in the tee fitting.
AFS
Installed oil temperature probe
ACS.
Install the tachometer cap.
Lycoming
Brad tighten the nuts on the forward side of the engine mount ears.
Fittings installed on the fuel pump
Tachometer cap and oil temperature probe
