Bob Leffler's RV-10
Date:  1-1-2011
Manual Reference:  46-2
Brief Description:  Re-doing the Cowl Hinges and Motor Mount
I realized yesterday as I was getting ready to put on the nose gear strut that I forgot to put the spacer on the side cowling hinges. This meant I had to take the motor mount off and drill out all the rivets on the side cowl hinges.
I then re-riveted the side cowl hinges after I added both the right and left spacers. After the hinges were riveted, I re-installed the motor mount.
I finished the install by measuring the torque on each bolt and installing the cotter pin on each of the bolts.
Renee assisted me today so I was able to accomplish things quicker than I did the first time around.
Not much changed except for the cotter pins are installed
