The CPC connectors that I had previously installed in the wing roots was having intermittent problems with the pins mating appropriately. Not wanted to spend the time to debug, I took out both connectors. I then rewired with DB25 pins and AMP connectors for the few lines that needed 10 amps.
This appears to have fixed all problems with the connections in the wing root.
