Although I'm not installing the Van's electrical harness, I did borrow some ideas from their plans. I drilled a pair of 3/4" holes on each side of the fuselage (F-1002 Bulkhead) to run wires through. Once the holes were drilled, then I installed a couple SB750-10 snap bushings.
45-15, Step 4
Mounted left door strut. Brad installed the brackets and strut. The door closes well and flies open since there is no weight on the door and the fact that I'm using the heavier gas struts.
