Bob Leffler's RV-10
Date:  7-17-2009
Number of Hours:  1.00
Manual Reference:  31-8
Brief Description:  Upper fuselage assembly, con't.
31 -8, Steps 10, 11, 12, 13, 14, & 15
Remove the subassembly of F-1003A Instrument Panel, F•1003B Instrument Panel Lower Flange, and the F-1003C-L & R Instrument Panel Attach Flanges from the F-1044A, F-1045-L, & F-1045-R Forward Fuselage Ribs. Remove the instrument panel attach flanges and instrument panel lower flange from the instrument panel. Final-Drill #40 the F-1071 Forward Fuse Top Skin to the sub-structure through all holes not yet match-drilled or final-drilled.
Remove the F-1003D and F-1003E Instrument Panel Attach Flanges. Using a nutplate as a drill guide, match-drill #40 two nutplate attach holes for each screw hole. Deburr all open rivet holes and edges of the instrument panel attach flanges then dimple all rivet holes EXCEPT the two most inboard rivet holes which lie under the F-1071B Hand Hold Doublers. Remove the Sub-Panel Forward Fuselage Rib Subassembly from the forward fuselage. Disassemble the Sub-Panel Forward Fuselage Rib Subassembly into its individual components. Deburr the holes and edges of all parts. Dimple the skin attach rivet holes in the F-1044A and F-1045-L & R Forward Fuselage Ribs, F-1068A Sub Panel Center, and F•1068B•L & R Sub Panel Sides. Dimple the nutplates that will be attached 10 the F-1003D & E Instrument Panel Attach Flanges and F-1083 Control Cable Bracket.
Rivet nutplates to the F-1003D & E lnst Panel Attach Flanges and F-1083 Control Cable Bracket. Rivet the F-1044B Angle, F-1044C Spacer, and F-1044D, E, & F Angles to the F-1 044A Forward Fuselage Rib
