Bob Leffler's RV-10
Date:  7-10-2009
Number of Hours:  1.00
Brief Description:  Adding an inpsection plate to the tunnel
Adding an inspection panel to the right side of the tunnel. I matched drilled all the holes on the doubler. I then drill positioning holes for the access plate and marked it's outline. I'll cut out the hole tomrrow.
Doubler all drilled
Doubler all drilled
Access plate mounted and cutout hole marked
