Bob Leffler's RV-10
Date: 7-9-2009
Number of Hours: 1.00
Manual Reference: 30-2, 30-3
Brief Description: Installing steps
30-2, Steps 5, 6, & 7
Adjust the position of the F-1038 Support Block to make the round portion of the WD-1 007-L Step parallel to both the upper edge and web of the F-1005A Rear Spar Bulkhead. Match-Drill #12 at least two of the holes drilled in Step 1 into the F-l020-L Middle Baggage Rib. Temporally bolt these holes to the middle baggage rib. Remove the step and match-drill #12 the remaining holes.
Remove the F-1 022A-L Baggage Floor. Mark the top, aft and outboard face of the F-1038 Support Block. Remove the support block. Deburr the holes in the F-1020-L Middle Baggage Rib.
Remove the WD-1007-L Step and set it aside. Bolt the F-1038 Support Block to the F-1020-L Middle Baggage Rib.
30-2 Completed per plans
30-3, Steps 1, 2, & 3
Adjust the span wise position of the WD-1007-L Step so the weld at the top of the step is flush with the F-1070-L Middle Side Skin
Use the dimension given set the proper sweep angle of the WD-1007-L Step. The dimension given is from the lower aft edge of the F-1004B Center Section Bulkhead stub to the leading edge of the step (not the leading edge of the step end plate).
Once the sweep back angle of the WD-1 007-L Step has been set, use the guide hole, match-drill #30 through the step, WD-1001-B Step Mounting Bracket and F-1077 Middle Bottom Skin.
Unfortunately, my 12” #30 bit got bent when I made this hole on the right step, so the steps are on hold until I can get the bit replaced.
Right step drilled
