Brad stopped by this afternoon and we finished riveting the last five rows on the bottom skins of the rear fuselage.
26-7 finished per plans.
28-4, Step 1
I started to remove material from the control column mounts. While cutting the second one, my band saw blade broke. I've been using 1/4" blades and thought I would try 1/8" blades. For some reason, I can't get the 1/8" blades to stay on. I've order a pair of 1/4" blades, so I'll have to finish these next week.
Gretz Heated Pitot
Brad and I tested the pitot again. It worked fine for a couple minutes and then stopped working. I pulled the control module and will be sending it back to Angus Aviation in Australia. Unfortunately, the shipping will cost more than the parts are worth.
