Bob Leffler's RV-10
Date:  3-26-2009
Manual Reference:  27-2
Brief Description:  Started the firewall
It rained again today, so I couldn't finish painting the fuselage skins, so I started on the fuselage firewall section.
27-2, Steps 1, 2,3, & 4
Cleco'd, match drilled, deburred, dimpled, and riveted the four corners of the firewall recess panel.Cleco'd the upper angle, lower channel, right and left side angles, left and right center angles, left and right diagonal angles, parking brake bracket (from Airward - Dave Ward), left and right upper firewall brackets, left and right lower firewall brackets, left and right nose gear tension fittings to the firewall bulkhead.
Parts cleco'd to the firewall
